Starting / Power issue.
Old Jun 15, 2024 | 10:06 AM
Phil m's Avatar
Default Starting / Power issue.
My 1999 XKR has an issue when starting which I would appreciate some advice with, when I try to start the car it basically just clicks when I turn the key but once I connect my jump starter and boost it the car starts straight away no problems.
The battery is brand new.
I changed the Alternator for a reconditioned one after the garage tested the battery when it was running which read 12.5.
The starter motor must be okay as it starts fine once boosted.
Has anyone else had the same issue or can you suggest something else I could check?
Old Jun 15, 2024 | 12:15 PM
RichardS's Avatar
I would check the actual rested voltage of the new battery after fully charging it overnight. I would also remove the battery clamps and clean and refit them.
Richard
Old Jun 15, 2024 | 12:45 PM
Phil m's Avatar
Richard
Thanks Richard I'll try that, daft question though what's the best way to clean the clamps?
Old Jun 15, 2024 | 03:41 PM
RichardS's Avatar
A piece of sandpaper or similar rubbed around the inside of the clamps and then around the battery terminal just to bring back the brightness to the metal.
Richard
Old Jun 15, 2024 | 05:47 PM
michaelh's Avatar
It's also worth checking the condition of the cables 'while you're in there' - make sure they don't get hot when you attempt a start.
Some have had issues with loose connections to the 'high power protection module' in the boot. See this thread from ccfulton:
https://www.jaguarforums.com/forum/x...1/#post1726815
Old Jun 19, 2024 | 10:36 AM
Phil m's Avatar
I thought I would give you and any future readers an update.
I checked and cleaned the battery clamps along with the high power connection modue and all was good.
Tested the new battery 11.57 volts but after charging it was 13.17 volts.
Tested the old battery 11.50 volts which was 12.47 volts after charging so not as knackered as I thought.
Put the new battery on the car turned the key and she fired up straight away so I tested the Alternator with the car running which came out at 14.41 volts so thats fine.
It could have been a mixture of charging the brand new battery and cleaning the connectors but it shows you that relatively simple things can make a big difference, it's also amazing how quickly a battery can be drained.
Thank you again for your help.
Old Jun 19, 2024 | 10:40 AM
michaelh's Avatar
Thanks for the feedback.
$0 fixes
Old Jun 19, 2024 | 10:48 AM
Phil m's Avatar
$0 fixes
That's my favourite kind of fix.
Dixter
Aug 5, 2016 03:05 AM
isecxf
Nov 6, 2015 10:02 AM
parforbob
May 6, 2013 02:26 PM
joco1976
Aug 10, 2009 05:11 PM
GolfJason
Jun 4, 2009 02:16 AM
