Steering column memory
Old Mar 1, 2022 | 10:00 AM
galearmstrong's Avatar
Default Steering column memory
1999 XK8 steering wheel doesn’t retract anymore when vehicle is turned off, but hear the ding like I’ve left the key in. Open the door the next day and ding…not sure if that is draining the battery, I keep a battery tender plugged in.
Anyone have an idea what’s going on and how to correct?
Old Mar 1, 2022 | 10:11 AM
fmertz's Avatar
Check the little trap door where the key fits. It sometimes gets stuck and the car "thinks" the key is still in the ignition. Lubrication is "key" here. Graphite-based products are great but can stain pants pockets. I would go with a silicone-based sprays, but not sure how durable it would be. And yes, this would normally drain your battery. On the flip side, you now have a (near) $0 fix to look forward to.
Best of luck, keep us posted.
Old Mar 1, 2022 | 11:18 AM
Jon89's Avatar
I try to remember to lube the ignition switch trap door with powdered graphite at least a couple of times a year. Dab a small amount of powdered graphite on the tip of my key, then insert it into the switch and turn the cylinder. Remove key, apply one more small dab on its tip, and repeat. Thoroughly wipe off the key afterwards. Works for me....
Old Mar 1, 2022 | 12:35 PM
You guys are GREAT…..$0 cost repair. I learn something new with every logon.
philip295
Jan 17, 2018 08:50 AM
Cherry_560sel
Aug 12, 2014 10:44 PM
texevora
Mar 28, 2014 01:50 PM
drk1074
Feb 21, 2011 11:24 AM
