suspension fault
Old Mar 26, 2021 | 10:21 AM
aeginc77's Avatar
Default suspension fault
The suspension fault light is showing on the dash. I connected an OBDII scanner to see if it showed any codes. I got nothing. Does the suspension system communicate through the OBDII system? If not what is the procedure for identifying and resolving suspension issues.
Alan
Old Mar 26, 2021 | 10:39 AM
motorcarman's Avatar
Yes the suspension module communicates through the OBDII port. (sort-of)
You need a device to read Chassis DTCs. ('C' codes)
A regular one only reads 'P' codes. (Powertrain)
Elegancec
Jan 29, 2023 03:28 PM
Eloquaint
Sep 9, 2019 06:30 PM
alexander thegreat
Jul 6, 2019 11:24 AM
silversurfer1221
May 10, 2016 08:00 PM
