temperature and oil pressure problem...help please
Old Jul 8, 2008 | 06:55 AM
test point's Avatar
Default RE: temperature and oil pressure problem...help please
Todd,
I am certainly not a guru but I would suggest that you chase the sensor/electrical side before tearing into the mechancial. Remember, the oil pressure guage is not an analog guage but simply an idiot light disguised as a guage. Sending unit is located down near the oil filter.
Unless the head work left a large oil passage open when it should not be I cannot see why that would have caused the problem.
Old Jul 8, 2008 | 12:00 PM
rscultho's Avatar
I once had a Bonneville (I was young!) and I had the same problem with oil pressure you are describing. It was fine when I first started it but after about 30 minutes (just long enough to get to class) the pressure would drop. Usually it sat for several hours while I was in class and when I came back out the pressure was fine. Then I would drive it to work and by the time I got there the pressure had dropped again.
The problem turned out to be trash in the oil pan. Apparently when I first started the car, the screen on the end of the pickup tube in the oil pan was clear and the pump could pull the oil freely from the oil pan. As I drove and the oil in the pan circulated, the trash would accumulate on the screen of the pickup tube and block the pumps ability to pull the oil from the pan. I took the pan off and sure enough, it had a lot of trash in it. I cleaned it off, put it back on and the problem went away.
But I agree with test point - check the smaller stuff/sender before tearing into mechanical possibilities. I hope your pump is not gone.
I don't know if you can change the oil pump out on these engines without cracking open the block.
Old Jul 8, 2008 | 08:04 PM
GordoCatCar's Avatar
Buy yourself an aftermarket oil pressure gauge and a T-fittingto add the appropriate sender unit [while maintaining the idiot light OEM 'gauge".
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
trebor12
UK & Eire
Sep 12, 2015 12:21 PM
chatmanx
Sep 11, 2015 07:17 PM
giandanielxk8
Sep 6, 2015 07:21 PM
