Timing chain
Old Apr 19, 2013 | 07:24 PM
paulab's Avatar
Default Timing chain
How can I tell if my car has had timing chain updates?
Old Apr 19, 2013 | 08:30 PM
Jag#4's Avatar
Pull the cam covers and take a peek. I assume you meant the secondary tensioners. Timing chains are pretty reliable on these cars.
Difference between plastic and metal tensioners is obvious. Pulling the covers is simple. Search for threads on replacing the tensioners (there are many) and several will show how to remove the covers.
I think Gus' site, jagrepair.com, has both procedures for replacing with the jag tools and with the zip-tie method.
Old Apr 20, 2013 | 07:03 PM
paulab's Avatar
Pulled one cover, ordered new tensioners. Hope to have it up and running next weekend
Old Apr 20, 2013 | 07:08 PM
WhiteXKR's Avatar
Paul- Did you order the shorter bolts also?
Old Apr 20, 2013 | 08:41 PM
paulab's Avatar
Yes, they are included
Old Apr 26, 2013 | 08:19 PM
paulab's Avatar
Found time to install new tensioners tonight, no problem. Test drive tomorrow, well see if ignition problem returns.
Old Apr 26, 2013 | 08:35 PM
test point's Avatar
Contrats!
You are now one of the forum experts!
Old Apr 26, 2013 | 08:53 PM
giandanielxk8's Avatar
paulab, how long did it take you? I already have the tensioners and bolts, but otherwise, I've been postponing it until I'm done with finals. I've also had my parents and grandparents telling me not to do the work on the car, that it is better to have a mechanic do it. They know how much thats costs, but they seem to prefer going through that expense. They think I'll bork the engine. What are the probabilities of borking the engine by doing the work myself?
I'm going to buy the gaskets as well. Can I find the appropriate gaskets in Pep Boys?
Old Apr 27, 2013 | 04:09 AM
test point's Avatar
The gaskets for your 2000 MY AJ27 are the same as the 2000 Lincoln LS and should be available at Pep Boys.
Of course, it is possible to screw up the process. Just be careful and put things back as you found them. One of the greatest issues is leaving a bolt loose or breaking one off but that is just a matter of experience in working on engines.
Old Apr 27, 2013 | 06:03 AM
RJ237's Avatar
It's unlikely that a engineering student would have difficulty, particularly with the forum to assist.
Old Apr 28, 2013 | 07:23 AM
paulab's Avatar
it was a simple job, use zip tie method and take your time.
Old Apr 28, 2013 | 09:49 AM
I'm not an engineering student... I'm a pre-med student. What ever gave you the impression that I'm studying engineering?
Well, paul, if you say so, then I'll give it a go after finals in 2 weeks. I need to buy a torque wrench, the gaskets, small plastic bags and the zip ties.
Old Apr 28, 2013 | 10:45 AM
RJ237's Avatar
Sorry, my memory failed me again.
Old Apr 28, 2013 | 11:07 AM
Vector's Avatar
He was thinking of human engineering.
We really are wonderful machines, as you probably have discovered in your studies.
Vector
Old Apr 28, 2013 | 11:56 AM
Happens to all of us at some point.
Vector
Yeah, it still amazes me.
Old Apr 28, 2013 | 07:29 PM
paulab's Avatar
Just do one side at a time, make sure you turn engine ( by hand) so all exhaust valves are closed. That way moving cam will be easy. I also put a mark with a paint marker on the chain and sprockets just in case . Good luck
Old Apr 28, 2013 | 07:59 PM
jaglover922's Avatar
I wouldn't say they are reliable. There's a reason the updated tensioners were introduced.
Old Apr 28, 2013 | 09:12 PM
Paul Pavlik's Avatar
The word "they" in the above quote refers to the Chains.
The reliability of the Chains was never in question.
The Original Tensioners were poorly designed and will fail at some point.
Tensioner Failure was not caused by the Chains.
RoyLittle0
May 25, 2023 02:38 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
Dicque
Sep 19, 2015 12:53 PM
Bowman
Sep 15, 2015 06:54 AM
Dicque
Sep 4, 2015 12:50 PM
