timing chain tensioners (where to find & part number)
Old Apr 29, 2013 | 11:00 PM
spuddyo's Avatar
Originally Posted by White Bear
I replaced the secondary tensioners in my 98 XK8, but there is still a slight rattle on cold start for a second or so. I am thinking about changing the secondary chains, along with the primary's and related tensioners and guides.
Regards,
White Bear.
It will take a second or two for the oil pressure to build up in the tensioners. If the rattle goes away immediately and doesn't repeat when revving from idle, you should be OK.
Old Apr 30, 2013 | 05:15 AM
WhiteXKR's Avatar
I would really appreciate it if any one can tell me if the 1998 Ford Thunderbird parts are the same as Jaguars? Buying them from a Ford dealer would almost certainly save money.
Regards,
White Bear.
Did you switch to the shorter bolts on the new tensioners?
Also, observe the belt tensioner with a bright light at cold start...is it vibrating? If so, this could be a bad idler pulley.
Old Apr 30, 2013 | 02:08 PM
White Bear's Avatar
Spuddyo,
Thanks for the reassurance, the rattle only lasts for a second or so, and does not occur in starts later in the day, it only occurs on cold starts, and is very noticable if it has not been used for several days.
WhiteXXR.
Yes I did install the shorter bolts, and will take a look at the idler pulley.
Thanks for replying.
Regards,
White Bear.
Old May 25, 2013 | 12:25 PM
goingjag's Avatar
Default Early model gasket set
I have a 98 XK8, and another poster mentioned getting the gaskets from British Parts UK.
I thought I'd add a couple of cents to that.
After looking around eBay and other parts suppliers I ended up at the British Parts UK site. A little scary because they only quote in pounds and don't indicate specific shipping costs/time.
The advantage of their set is that it includes the valve covers, o rings and bolt rings which no other kits included.
Of course the other main advantage is those are all included at the lowest cost I could find. 41.15 pounds which at current rates appeared to be about $62.
So I decided even if there was a higher exchange rate on my credit card and they charged $30 shipping, it would still come out cheaper than any other alternatives.
Well it turned out they charged 10 pounds or roughly $15 for shipping.
I ordered the tensioners from Sunford in California on Sunday, they arrived Wednesday. I ordered the gaskets that same day from British Parts UK and they arrived Saturday (make sure someone is around you have to sign for them). Invoice total was 51.15 pounds and I looked on my credit card account and the exchange remained reasonable at a total cost of just under $78. You'll be hard pressed to find just the 2 valve cover gaskets on eBay at that cost with shipping.
Now I just have to get in there and do the work
Thanks again to all the earlier posters for the details on how to do the job and various tips.
xjrjag
Nov 27, 2025 09:16 AM
kurtomatic
Feb 12, 2024 06:58 AM
lobsterD90
Nov 12, 2022 09:51 PM
Bcrary3
Sep 12, 2015 08:43 AM
souldoubt
Aug 25, 2015 08:15 PM
