Timing cover oil seal - only $145.00??
Old Mar 12, 2015 | 11:09 AM
cruisin's Avatar
Default Timing cover oil seal - only $145.00??
Does anyone have a part number for a generic timing cover/crankshaft oil seal for the 4.0? surely there is one that will work for this application. the best price I found was over $60.00
Thanks,
Russ
Old Mar 12, 2015 | 12:10 PM
Paul Pavlik's Avatar
Thanks,
Russ
Rock Auto, VICTOR REINZ Part # 67778 $8.95
Old Mar 12, 2015 | 01:36 PM
cruisin's Avatar
You are my hero .
I had tried Rock Auto first , without success. then after you said you found it there I just had to find out how. I guess I should have looked under Lincoln LS. I gota remember to use that trick in the future as well.
Many thanks Paul,
Russ
Old Mar 12, 2015 | 05:25 PM
You are my hero .
Many thanks Paul,
Russ
I found under Jaguar, 2000, XK8, Engine, Timing Cover Seal. However, I don't see it for the 1999 XK8. But they both are AJ27 Engines.
xjrjag
Nov 27, 2025 09:16 AM
SD96XJ6L
Jan 12, 2022 04:30 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
peterg19
Aug 28, 2015 08:42 AM
Will P
Aug 27, 2015 06:52 PM
