Tiny screw for the shift knob?
Old May 18, 2011 | 07:11 AM
Dave S's Avatar
Default Tiny screw for the shift knob?
Well, I finally got my XKR out of the shop and am about to drive it cross country. I'm pretty excited. While it was in the shop, I found quite a few of the parts I had been missing (and didn't know!) like the spare tire, tire kit, etc... The MOST exciting find was the correct MOMO shift knob that someone had made off with over the life of the car. (It had been misdescribed on eBay and it was pure luck that I found it...)
ANYWAY, it looks great back on the car, but I've got a small issue. When it's all the way screwed down tight, it's about 90 degrees off from where it should be (too far clockwise). There's a tightening screw located in the neck of the shifter that's made to correct this - hold it tight at whatever screw-point it's at.
My problem is that I don't have the screw for it. And it's tiny. I don't have anything that I can even measure the screw diameter and/or thread count with. I believe it's around 1/8 inch in diameter, and probably about 1/2 long and the head is probably small enough to fit into the tiny hole when screwed all the way down.
Unfortunately, no local hardware store has these screws, nor does any auto part store. It's probably costs less than a dollar...but I can't find one at all.
Does anyone on here know what the part number might be? Or perhaps what size screw it really is so I can google one?
ANY help is appreciated!
Dave
Old May 18, 2011 | 10:32 AM
BobF's Avatar
Set Screw, usually with hex head. Grainger will have otherwise try a local pumbing or machine shop.
X308XJR
May 20, 2019 06:50 PM
danke
Oct 3, 2015 09:31 PM
mrplow58
Sep 30, 2015 08:56 AM
dansxj6
Sep 28, 2015 08:02 AM
