Trans help needed
Old Mar 30, 2017 | 01:52 PM
Dale Dunn's Avatar
Default Trans help needed
trying to identify my fill plug. Found Allen plug by line but is 5mm and hole too small for pump. Second is large enough but is 19mm hex head. Thinking maybe latter is it and Allen was replaced with hex head. Any help appreciated.
Attached Thumbnails Trans help needed-img_0181.jpg   Trans help needed-img_0183.jpg
Old Mar 30, 2017 | 02:09 PM
BobRoy's Avatar
Dale, it is at te rear of the transmission on the right side, passenger side. It's a 8mm hex. The same size of the drain plug.
Old Mar 30, 2017 | 02:17 PM
Dale Dunn's Avatar
Ok. Thanks once again
Old Mar 30, 2017 | 03:14 PM
RJ237's Avatar
You can tell it's the right plug because you will be burning your arm on the exhaust pipe when you replace it with the engine running.
Old Mar 30, 2017 | 03:16 PM
dsd's Avatar
dsd
Title:
Trans help needed
First sentence:
Trying to identify my fill plug.
I LOLd. Apparently, I'm 12.
Old Mar 30, 2017 | 04:36 PM
BobRoy's Avatar
Originally Posted by dsd
Title:
Trans help needed
First sentence:
I must be getting old it took me a couple of minutes to figure that one out, and I'm only an hour from San Francisco.
