Transmission fluid for ZF5HP24
Guys,
In Bahrain, I’m struggling to get any recommended ATF fluid. The Jaguar Dealer only has ZF Lifeguard 8, not 5, and can’t find MerconSP, Esso 71141, or Mobile 220.
What I can get is Febi Bilstein 14738 or Liqui Moly 1200. Another problem is I have no idea what is already in the car transmission as garage mechanics in Bahrain tell me they use red Dextron ATF.
As this job is done only every 100,000km, I’m keen to choose the best fluid. Any thoughts?
BTW I managed to track down a busted gearbox and practised getting the upgraded Transgo pressure valve in. And springs did go flying as end plate screws are really short!
OK for power steering but you probably don't want the red stuff in your transmission...
Is there a VW agent locally? I read that there are direct equivalents that VW and Peugeot use. Motorcarman has the VW part # here:
https://www.jaguarforums.com/forum/x...1/#post1696528
magnum454
Mar 23, 2018 07:40 PM
jimlombardi
Oct 31, 2017 06:17 PM
jimlombardi
Jun 15, 2011 08:16 AM
jeiiomix
Sep 15, 2010 01:31 PM
eugene1175
Feb 16, 2010 07:43 AM
