Transmission Issue!!
Old Jun 29, 2008 | 10:51 AM
uk4545a's Avatar
Default Transmission Issue!!
Well, my worst nightmare is happening. I just purchased a 97' XK8 with 34,500 miles on it a month ago. Was running fine, now as of last night the transmission is winding out in all gears, and it will not shift gears if I try to use the manualshift changer. I also hear a clicking from the tranny when I shift it into drive and/or reverse. In addition, the temperature gause goes to red after driving it about 10 minutes, but will fluctuate at times back to normal?? Someone please tell me this is something simple!!
My wife is giving me the "I told you so" stating Jaguar's at times less than stellar reliability reputation.......[>:]
Old Jun 29, 2008 | 11:09 AM
GordoCatCar's Avatar
Default RE: Transmission Issue!!
The temperature issue could be a sticking thermostat. It is closed on startup, but then fails to open when reaching operating temps. Sometimes it does not stick, and the temperature is fine. Easy Fix. New Thermostat. PS> While you are fixing things, get an aluminumt-stat [replacing the plastic version] housing like this: http://www.britishparts.com/jaguar-d...g-aluminum.pdf
As for the trans acting up, I don't know.
Old Jun 30, 2008 | 03:01 PM
uk4545a's Avatar
Thanks for the info Gordo. Possibly the transmission is going into "limp" mode when the thermostat rises. Makes sense since it drives fine before the temp goes up....
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
XJsc-guy
Sep 25, 2015 11:09 AM
carelm
Sep 5, 2015 01:13 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
