two post lift - lifting points for 2002 XK?
Old May 12, 2017 | 12:13 PM
Cabel's Avatar
Default two post lift - lifting points for 2002 XK?
I found the jacking points easy enough but nothing specific to safely lifting my XKR on a two-post lift. Anyone have a link to an image or diagram of those points? Thanks.
Old May 12, 2017 | 03:22 PM
RJ237's Avatar
Are you saying your two post lift doesn't have two arms on each side?
Old May 12, 2017 | 06:43 PM
Cabel's Avatar
No, typical two-post lift with four arms. The only diagrams I have seen are for the four "jack points", which are sometimes different than the "lift points", at least I hope they are as the left rear jack point on my car is crushed and I don't feel safe using the lift at that point.
Old May 12, 2017 | 06:52 PM
RJ237's Avatar
I have been using the jack points with my scissors lift for years. When I pulled the transmission I had to shift the car forward so I put a six foot 2x6 on the jack pads each side and used the full length of the ridge at the bottom of the rockers to support it.
