Valve cover leak,, Same place both sides
Old Sep 24, 2012 | 08:47 AM
Ed Fast's Avatar
Default Valve cover leak,, Same place both sides
I just bought a 1999 xk8 and took it for a little spin. 140mph for 5 miles and then I could smell oil. I pulled over and popped the hood. I have oil that looked to coming from the back of the valve cover at the same spot on each side of the engine. Is that possible. It seems to only (leak) at high rpm. Thanks for any help.
Levi
Old Sep 24, 2012 | 09:11 AM
test point's Avatar
The most common problem with valve covers leaking is that they were tightened down too much in an earlier repair cracking the plastic covers. Back corners are more subject than most of the other bolts because of more difficulty in reaching them. That level of RPM's for a few minutes may have pumped more oil into the valve area than could effectively drain back.
. . . and welcome to the forum.
Where did you find that much road without police protection?
Old Sep 24, 2012 | 09:13 AM
RJ237's Avatar
Welcome to the forum. Please visit the new member area and introduce yourself:
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Do NOT try to tighten the valve cover to stop the leak without a little information. You can crack the cover or strip the threads if you go much beyond 9-11 Nm torque. Tightening probably will not work, and you will need to replace the gaskets, which can be done with 2001 Lincoln LS1 set. While doing so see if you have the plastic chain tensioners, which must be changed. Lots of info on that and other upgrades on this site, just use the search function.
RJ_______________
97 XK8 86K mi
Old Sep 24, 2012 | 09:34 AM
Ed Fast's Avatar
Default Jag
I just hit in on the interstate threw town. Fuzz buster and called it good. Not a very good Idea but I needed some speed. basically why I bought the car. want to go fast in comfort.
Old Sep 24, 2012 | 10:56 AM
test point's Avatar
MN or WY?
Old Sep 25, 2012 | 10:25 AM
Ed Fast's Avatar
Default wy
wyo
tberg
Sep 7, 2015 07:32 AM
David Thompson
Sep 3, 2015 07:48 PM
Dallas XK8
Sep 3, 2015 12:17 PM
OkieTim
Sep 2, 2015 12:48 PM
XFR_Gold
Sep 2, 2015 12:24 PM
