Valve covers and Differential....
Old Feb 17, 2018 | 08:34 AM
jaguar51's Avatar
Question Valve covers and Differential....
Graham, thanks for the diagrams. I understand the valve cover gaskets are a PITA to change out, would you agree? Because the differential drive oil plug is in a tough spot to reach do you have a "trick technique" to get it out and back in without having to drill a 3 inch hole thru the rear boot wall to directly access it? Can the breather vent on top the diff be cleaned out with break cleaner and then blow out with compressed air and reinstalled?
Cheer,
ER.
Old Feb 18, 2018 | 10:35 AM
I've moved this question from your Rear Brake Pad Replacement/Recalibration thread to a new one.
You will always get better responses by keeping topics separate.
Old Feb 18, 2018 | 08:19 PM
Gus's Avatar
Gus
This is how I did my 99 differential
Old Feb 18, 2018 | 08:22 PM
Gus's Avatar
Gus
And valve cover gaskets
OUScooby
Jan 11, 2019 09:45 AM
PeterMAX
XK120 XK140 XK150
Jun 13, 2015 08:56 PM
stremsjg
Detailing / Car care
Aug 23, 2010 07:04 AM
99kyxjr
Mar 13, 2010 12:41 PM
philsk8ts
Feb 8, 2007 11:27 PM
