Valve stem seals.
Old Jun 7, 2021 | 10:51 AM
RaceDiagnostics's Avatar
Default Valve stem seals.
Has anyone changed theirs with the heads in place using rope or compressed air?
Old Jun 12, 2021 | 01:51 AM
Pistnbroke's Avatar
Why not just put some of that seal expander in the oil...expands the rubber 4% and would be good for the crank seals too.
Old Jun 12, 2021 | 04:09 AM
Since I can't find any trace of anyone doing this job on the car with the heads still in place, that may be the only easy option. At the moment it is no big deal, just an occasional puff of smoke on start up. I wouldn't pull the heads off at this stage, too much expense involved to do that.
Doing the job on the Merc was pretty easy.
Old Jun 12, 2021 | 04:17 AM
Pistnbroke's Avatar
Sounds like a trace of oil going down a stem and then burning off at startup so the oil additive would expand and soften the seals. In the UK its called "Engine Stop Leak" I would be looking at compressed air myself ..simple plug adaptor and 90 psi .Keep the compressor running !
max224
Sep 30, 2022 05:09 PM
grantp
Mar 7, 2020 01:53 AM
max224
Dec 9, 2015 09:04 AM
blackcat03
May 28, 2015 01:57 PM
