Water in fuel door
Old Oct 26, 2017 | 04:44 PM
Loxmth's Avatar
Default Water in fuel door
Got water in the fuel door. What's the best way to clean the drain or should I replace it.
Old Oct 26, 2017 | 04:57 PM
Johnken's Avatar
I'd push a wire through or shoot compressed air into the port ( if u have a compressor). As I recall the drain is pretty much straight down.
John
Old Oct 27, 2017 | 09:43 AM
graham11's Avatar
Same happened to me last month,just got a roll of soldering wire and thred it down the drain hole as I recall going of the lenth of wire it took to unblock the drain pipe is around 12"
Old Oct 27, 2017 | 10:40 AM
I usually find they block at the bottom of the drain tube - plugged with mud.
Old Oct 28, 2017 | 07:48 AM
Loxmth's Avatar
Thanks guys. Was afraid it would be lots of rust. Going to use wire first then get some compressed air through it.
