What is normal Spark Plug Insulator Color ?
Old Nov 8, 2015 | 08:54 PM
64vette's Avatar
Default What is normal Spark Plug Insulator Color ?
I have a (new to me) 2000 XK8 that I am going thru revitalization after several years of storage. I pulled the spark plugs today and was surprised that they basically look new other than light carbon around the base of the threads. I had already purchased a set of new NGK Iridiums so I'll replace them anyway.
According to PO and records the plugs have not been replaced. Car has 95,000 miles. My question is: The left bank plugs all have bright white insulators, and the right bank are all very very light tan. I am used to seeing some color on the insulator. Is this lack of color normal ?
There is no evidence of overtemperature or blistering on the plugs. Using a scope to look at the top of the pistons there is a light coating of carbon and you can still see the triangle (or is it an "A" ?) clearly, and again no indication of overtemperature.
Old Nov 9, 2015 | 07:26 PM
White Bear's Avatar
Normal color (UK colour) is light tan. Check the fuel trim for left bank, it may be running lean.
Regards,
