Jaguar Forums - Jaguar Enthusiasts Forum (https://www.jaguarforums.com/forum/)
-   XK8 / XKR ( X100 ) (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/)
-   -   Whats The Cheapest Effective Way To Make Stock XKR Exhaust Loud Like A Aston Martin ? (https://www.jaguarforums.com/forum/xk8-xkr-x100-17/whats-cheapest-effective-way-make-stock-xkr-exhaust-loud-like-aston-martin-71020/)
jagxkrtoofast Apr 3, 2012 03:23 PM
I driven the AM DB9 before and the exhaust sound is awesome. I would like to my stock XKR exhaust sound like the DB9. Is there any cheap options available ?
roymattblack Apr 3, 2012 03:50 PM
Basically, no.
The DB9 is a Straightforward V12.
The XKR is a supercharged V8 - they are never going to sound the same.
An excellent sound option though is to replace the two back boxes with Adamesh straight through pipes.
It too sounds amazing - more like a Maserati than an Aston.
Roy.
jagxkrtoofast Apr 3, 2012 06:45 PM
Any other options ?
avt007 Apr 3, 2012 08:06 PM
What year XKR? Another posting that pulling fuse 19 on his 2005 opened all 4 exhaust pipes. Does that help?
jagxkrtoofast Apr 3, 2012 09:14 PM
04
avt007 Apr 3, 2012 09:45 PM
https://www.jaguarforums.com/forum/x...-19-etc-71035/
jagxkrtoofast Apr 3, 2012 10:15 PM
Does fuse 19 apply to the 2004 ?
XKRacer Apr 4, 2012 12:03 AM
X100s 1996 through to 2005 do not have active exhausts
X150s do
80sRule Apr 4, 2012 07:51 AM
Originally Posted by roymattblack (Post 493517)
Basically, no.
Roy.
Not that sounding like a Maserati is a bad thing! A V12 will have a howl that you just can't get from a V8. The XKR sounds different, not better, not worse.
I love the sound of my XKR(although it is quite quiet), and the V8 in my Audi has a great noise too. The strait pipe option for the XKR has been something I've considered, have you done this?
K.Westra Apr 4, 2012 10:38 AM
There are tons of exhaust threads on here if you do some searching. Here is my system: https://www.jaguarforums.com/forum/x...ter-40s-37811/ It is on the louder end of the spectrum, but I love it. As a bonus, it isn't too expensive (although removing mufflers and replacing with pipe is still going to be cheaper)
roymattblack Apr 4, 2012 11:09 AM
I think that without spending too much, and without ending up with a 'noisy' car from the drivers point of view, the straight tails are the best option.
They will be 'sedate' when driving round town etc, but when you floor it, or want a bit of drama, they give it in spades!
Mine is a standard XK8 (not the XKR) and when I floor it, it turns heads.
Someone actually said to me that 'It sounds like a bl--dy Ferrari!'.
This was actually said by a non-car person, so I know it doesn't actually sound like a lump of Maranello, but I do know exactly what they meant.
Get the straight tails.
Cheap, fantastic.
Roy.
jagxkrtoofast Apr 4, 2012 05:52 PM
Straight pipes ? How about remove all mufflers with the exception of one ? I want my exhaust to be really loud so when I pass by people can hear it.
Vector Apr 4, 2012 09:53 PM
How about electric exhaust cut outs? You don't have to open them all the way.
https://www.jaguarforums.com/forum/x...ut-outs-68743/
I should have mine installed soon.
Vector
edtexas Apr 5, 2012 12:57 AM
If you want some great loud sound, coupled with a respectable increase in power for the money, you might have a custom exhaust shop build you an exhaust similar to a Macleod x-pipe. He claimed about 12+ hp. Pre-made x-pipes can be bought on Ebay and Amazon
This is a link for the sound. It sounds pretty scary to passers-by.
MacLeod MK II X-Pipe - YouTube
This is made out of 2.5" stainless. The exhaust has very few bends in it and goes under the axle instead of over it like the stock exhaust does. Here's a link of the components.
I believe he used Magnaflow exhausts (I may be wrong). If you want a louder note, you could try a set of Flowmasters at the rear. My neighbor installed Magnaflows on his brand new Chevy pick-up. I thought they sounded great, but he wanted something even more ominous. He installed a set of Flowmasters. It sounds nasty. (in a good way) and definitely louder.
Link featuring pics of Mcleod exhaust system and installation:
MacLeod mkII x-pipe install - Jano Lukac's Photos
You can probably have something like this done at an experienced shop for around $1K.
There are lots of videos of Jag exhausts on YouTube, and lots of discussions about the Mcleod exhaust and its power on this forum. You might also consider a set of new
Nameless Performance downpipes that add more power and may also add to the flavor of the exhaust note. This is a quality product that has passed emissions tests in California. They run about $900. They are also a sponsor on this site. Good luck.
Frog Apr 5, 2012 01:24 AM
I replaced the back boxes with straight through pipes. It sounds a bit meatier, especially on start-up and overall volume has gone up around 20%. No droning at cruising speeds.
2005 Jaguar XKR with XKZ exhaust - YouTube
jagxkrtoofast Apr 9, 2012 08:20 PM
Need more recommendations.
dx3 Apr 10, 2012 02:46 PM
I guess I don't understand what exactly you are looking for... You've been given a brunt of answers.
Just got have some custom mandrel pipes bent with 2.5" pipes and either go straight back or go into some free flowing (open mufflers). Although depending on what state you are in there may be emissions restrictions to consider.
XKRacer Apr 10, 2012 02:52 PM
The biggest problem with this thread is in the title, the word "Cheapest" is mentioned...lol
The exhaust I use to produce people would say was very close to an Aston, but that was $1800
Tiko89 Apr 10, 2012 04:34 PM
Garage-floor envy...is that tile on your floor, Frog? Does that hold up under parking?
My garage had epoxy when we moved in but it's starting to look pretty shabby.
enderle Apr 14, 2012 02:44 PM
The Adamesh straight pipe swap worked wonderfully for me. Little bit of work (mostly to get the old pipes off) and it sounds wonderful now. Be aware than Mina Gallery is working on a better solution (better as in they don't intend to crimp the pipes when they bend them and hangers will be improved) but this is a cheap quick fix.
© 2026 MH Sub I, LLC dba Internet Brands
