wheel alignment
Old Apr 8, 2013 | 01:07 PM
randyb's Avatar
Default wheel alignment
I had new tires put on and they checked my alignment and told me I was 1 degree in at the top of my front passenger tire.
Do you need special shims for jags?
Old Apr 8, 2013 | 01:53 PM
Jag13cat's Avatar
Default Front Alignment
RandyB: On the front A-Arms, Jaguar has what is called an adjustment bolt and fulcrum shaft for adjusting camber. There are no shims, per se, to adjust camber as in the rear end components. There are spacers (washers) at each end of the respective bolts of the lower and upper A-Arms. Having said that, there are other contributors to camber being out, such as saging springs, bushings, etc. Without knowing exactly what the alignment shop is telling you, it should be able to diagnose and refer to a repair manual for specifics as to what should be done.
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
DustysSon
Sep 13, 2015 04:17 AM
lickahotskillet
Sep 11, 2015 07:54 PM
ferraripete
Sep 10, 2015 01:24 AM
