Where does this plug connect? (ECU boxes location under front bonnet)
Old Dec 13, 2023 | 07:23 PM
Wolvesboy's Avatar
Default Where does this plug connect? (ECU boxes location under front bonnet)
Hi All,
I disconnected my ECUs x2 located in the front left of engine bay. However, I found this plug and cannot work out where it should be plugged in!
FYi It has some black tape around it - I cannot see any connector anywhere and the ECU connectors all plug in as normal.
Any help is appreciated!
Old Dec 13, 2023 | 08:26 PM
baxtor's Avatar
Originally Posted by Wolvesboy
Hi All,
If you did not unplug it then it is most likely intended for an option or spec your car does not use.
Old Dec 13, 2023 | 09:24 PM
Wolvesboy's Avatar
Thanks for the quick reply, Baxtor.
However, why the tape? It does not "look" official to me and surely it would not come from the factory like that?
Qryoz
Sep 8, 2024 02:06 PM
thekiltedwonder
Aug 16, 2021 03:18 AM
Aidan2001
Jun 10, 2020 09:28 AM
Doug
May 22, 2017 03:56 PM
macudc
Sep 20, 2014 09:31 PM
