Where to hook up float charger?
Old Jan 8, 2017 | 10:28 AM
Shoreguy's Avatar
Veteran: Air Force
Default Where to hook up float charger?
Here in New Jersey like so many places across the country it's cold. My XK8 is in a unheated garage and I want to hook up a float charger. I thought I read in the forum some time ago that you should hook it up at the terminals under the hood not at the battery. Tried finding this info in a search but, couldn't find the related post. Thanks in advance
Cheers!
Old Jan 8, 2017 | 10:40 AM
joelsjag's Avatar
If you wanted to you could hook the charger up to the fuse box under the hood. I left my keys in the trunk once and the battery went dead. Hooked up some jumpers to a spare battery positive to the fuse box and ground to the frame and opened the trunk. I assume you could hook the float charger up to charge the batteries the same way.
Old Jan 8, 2017 | 11:41 AM
StuG's Avatar
Cheers!
https://www.jaguarforums.com/forum/x...rminals-56664/
Cheers,
Stu
Old Jan 8, 2017 | 11:49 AM
Shoreguy's Avatar
Veteran: Air Force
Thanks guys thought underhood was correct.
