where are these located?
2000 XK8 conv - have the new parts I need, but have been unable to locate the following: LJC1525AC and NJC6107EA so I can replace them.
thanks in advance
thanks in advance
The canister valve is between the two rectangular plastic black boxes (charcoal canisters) under the car between the two rear wheels.
You will also see the gas vapor breather pipe in that area where it goes off to vent at the right rear suspension housing.
Last edited by WhiteXKR; Jan 12, 2013 at 06:39 PM. Reason: Correction: right rear suspension housing, not left
Sorry Graham - need to replace the canister valve and breather tube (part #'s listed). I have the replacement parts just couldn't find them on the car.
WhiteXKR - thanks for the assist!!!!!!!!
jimforrest (uk)
Feb 28, 2019 06:42 PM
FS[SouthWest]: 19" Aquila Wheels with Tires
jorgef858
Jan 14, 2016 11:32 AM
