Will 1998 XK8 17" wheels fit 1988 XJ6?
Old May 13, 2009 | 09:59 PM
leeboy's Avatar
Question Will 1998 XK8 17" wheels fit 1988 XJ6?
I was wondering if 1998 XK8 17" wheels would fit on a 1988 XJ6?
The XK8 17" wheels have a 5 x 4.75 (5 x 120.65) bolt pattern with 245/50R17 tires on. Would these fit on a 1988 XJ6?
Old May 14, 2009 | 12:56 AM
wazari's Avatar
The bolt is the same, I'm not sure about the center bore diameter. If the center bore diameter on the '88 is 74 mm then the wheels should work.
Old May 14, 2009 | 10:11 AM
ken@britishparts.com's Avatar
Should be good to go. You may have some clearance problems on the rear fenders, but I doubt it.
toronadomike
Jan 22, 2026 10:13 PM
prettydaim
Mar 28, 2021 07:47 AM
David Thompson
Sep 3, 2015 07:48 PM
Harry Dredge
Sep 3, 2015 03:04 AM
Harry Dredge
Sep 2, 2015 02:26 PM
