wire and plug on the AC compressor
Old Mar 26, 2015 | 04:22 PM
Lufferman's Avatar
Default wire and plug on the AC compressor
I scoured the forum for help but couldn't find any relevant posts. My 99 XK8 has a Denso AC compressor with a 6 inch pig tail and a 2 prong plug on the end. This wire comes out of the bottom of the compressor. I've been cleaning the area extensively trying to find a leak from power steering pump. I came across the plug lying on the frame. I initially thought i may have unplugged it and on inspecting the plug it is damaged and would not stay plugged in without help from a ziptie adding to the thought that i may have unplugged it.I cant find anywhere to plug it within reach of the wire. I can only assume that the wire is for another application. Any suggestions? Does anyone have this wire on there AC? AC seem to be working fine. thanks in advance for the moral support.
Old Mar 28, 2015 | 08:54 AM
Lufferman's Avatar
No comments? This must be a first.
Old Mar 28, 2015 | 12:04 PM
jamdmyers's Avatar
Look around in my posts I've appended the 01 wiring doc, maybe you can find something there. I don't want to repost it since it's large
Old Mar 29, 2015 | 11:10 AM
Lufferman's Avatar
Default Thanks anyway
You have like 356 posts on fifteen pages I didn't see anything about my ac compressor wiring and as far as appended 01 wiring doc I did a search your quote above is all that came up.
Maybe someone also has a Denso compressor with a wire on the bottom. Just need to know that I didn't unplug it while cleaning I'd like to snip it if not needed.
Old Mar 30, 2015 | 07:27 AM
jamdmyers's Avatar
Here's one
https://www.jaguarforums.com/forum/x...y-unit-138231/
Old Mar 30, 2015 | 07:50 AM
Gus's Avatar
Gus
I recently replaced my A/C unit but I am not sure what you are looking for. As for the wiring I attached a link for your 99xk8
Link http://www.jagrepair.com/images/Auto.../jagxk1999.pdf
Old Mar 31, 2015 | 09:12 PM
Lufferman's Avatar
Gus, did you put on a Denso compressor?
Old Mar 31, 2015 | 09:17 PM
Gus's Avatar
Gus
Yes!
Old Apr 2, 2015 | 12:12 AM
Lufferman's Avatar
Default Pic
Did it look like this?
This is the wire exiting the bottom side of the compressor they are six inches long with plug lying on frame (out of shot). Ac ran fine today. I suspect them to be Dummy's for a different application. Do you recall these wires? Thanks for your time and consideration.
Old Apr 2, 2015 | 09:07 AM
Gus's Avatar
Gus
See if this helps
Attached Thumbnails wire and plug on the AC compressor-img_2483.jpg   wire and plug on the AC compressor-img_2492.jpg   wire and plug on the AC compressor-img_2493.jpg
Old Apr 2, 2015 | 11:30 PM
Lufferman's Avatar
Thanks for the pics. The wire I am questioning is not on your pumps. They would be sitting on the wires. i guess it for some other purpose. Thanks
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
jagent
Sep 12, 2015 01:40 AM
explorer364
Sep 11, 2015 05:44 PM
tonyforman
Sep 10, 2015 07:23 PM
Bones
Sep 8, 2015 08:34 PM
