XK8 door popping sound
Old Jun 13, 2017 | 06:12 PM
wymjym's Avatar
Default XK8 door popping sound
2005 XK8
I fear I have some 'popped' spot welds! When opening the drivers door I hear a clicking sound as the door fully opens. Te door pillar also appears to flex out quite a bit.
Is there any way to repair this without removing the door and/or fender?
or rather...how does one fix this issue?
wj
Old Jun 13, 2017 | 06:28 PM
A regular cause of clicking is a broken door checkarm .......
Old Jun 14, 2017 | 03:26 AM
laguillotine's Avatar
I have this too
It was on both doors but tightening the bolt on the pillar fixed the passenger side, but not the drivers side.
I have changed the check arm on cars in past to solve this but on my XK8 I too have noticed the amount flex in the pillar which made me doubt its just the check arm
Old Jun 15, 2017 | 06:44 PM
Jerry Lippmann's Avatar
My 98 XK8 started doing this a few days ago, then today a nut fell out (#7 in the photo) when I opened the door. My job for the weekend: Off comes the panel to sort this out. Might be simply securing fasteners, might be something broken. I'll find out and report.
Regards,
Jerry Lippmann
Old Mar 30, 2019 | 08:10 PM
taylods's Avatar
2005 XK8 same problem. GGG thanks for the exploded door view.
Yes the Checkarm was loose on my car, so I used a 10mm socket to tighten the bolt in TINY increments... test and slightly tighten again if needed.
3 times was the charm for me.
See video
