Xk8 Front Suspension exentric Bolt upgrade?
Old Sep 20, 2012 | 11:08 PM
Mendo XK's Avatar
Exclamation Xk8 Front Suspension exentric Bolt upgrade?
I'm rebuilding my front Suspension and I heard the make a new Bolt or something that gives you more adjustment for a Wheel Alignment. Does anybody have info on that one. Thank you!
Old Sep 21, 2012 | 03:05 AM
H20boy's Avatar
I think this is correct - its on the lower control arm, number 18 on this schematic (it replaces #12 on the front and rear arms) This is for a 2003+ out of the electronic parts catalogue.
Attached Thumbnails Xk8 Front Suspension exentric Bolt upgrade?-schematic.jpg
Old Sep 22, 2012 | 02:47 AM
twojagsv8's Avatar
Yes there is an eccentric bolt replacing the part no 12 which alters camber. I've replaced both of mine due to inner tyre wear problems. I'll post the part no when I get home. Make sure there are no other problems first such as weak springs or worn bushes and balljoints.
Regards
John
Old Sep 22, 2012 | 07:32 AM
andyps's Avatar
I have to replace all my bushes soon so that part number would be great John, I may as well get them to fit at the same time.
Old Sep 22, 2012 | 09:51 AM
twojagsv8's Avatar
The part number for the eccentric bolt for the lower suspension arm on the XK8 (1998) is JZB 100086
Don't let the dealer tell you it doesn't exist just because they can't find it.
Regards
John
Old Jul 8, 2013 | 12:10 PM
99ragtop's Avatar
Default Camber help needed!
Hi guys! My '99 lowered xk8 has severe negative camber issues front &rear. I've replaced upper &lower a-arms, sway bar bushings, and rack & pinion. My tires are taking a beating! The front shock mounts are crumbling (212,000) miles. Would putting taller tires on get rid of negative camber issues? I need a $ break for a while? PS the car tracks straight and makes no more clunks...just severe inner tire wear , front and back. Thanks, Andy
Old Jul 8, 2013 | 12:15 PM
WhiteXKR's Avatar
Here is a $10 fix for the strut mounts: https://www.jaguarforums.com/forum/x...0-bucks-77884/
Old Jul 9, 2013 | 12:21 AM
99ragtop's Avatar
Default Awesome!
Thank you so much for this link! I appreciate your efforts immensely. Warmly, Andy
Old Jul 9, 2013 | 09:24 PM
99ragtop's Avatar
Hi. Do you think poor shock mounts would contribute to negative camber issues? Thanks in advance, Andy
Old Jul 9, 2013 | 09:41 PM
WhiteXKR's Avatar
Yes
Old Jul 9, 2013 | 09:53 PM
GordoCatCar's Avatar
The eccentric bolt offset is probably not more than 1/16", meaning that is the distance the lower control arm can pull in the bottom of the wheel in an attempt to correct negative camber. I don't think it amounts to even a half degree of correction. I installed them on mine, and IMO it is not worth the time and trouble to install. Gordo
Old Jul 10, 2013 | 01:34 PM
99ragtop's Avatar
Thank you for your advice. My camber readings are all above negative 3. 1/16 won't fix it! Warmly, Andy
Old Jul 10, 2013 | 01:37 PM
99ragtop's Avatar
Default Thanks
Yes
Thank you for your definitive answer. I'm so involved in this camber/tires issue, your one-word answer was perfect. So shock mounts and differential shims are on the docket. Warmly, Andy
Old Jul 10, 2013 | 03:08 PM
H20boy's Avatar
IIRC, I think Brutal (one of our jag techs) said the eccentric bolt gained you up to 0.5 degrees of camber. Nothing dramatic, but it is still something.
When I replaced my shocks separately from the upper mounts, I also found that I gained another 1/2" of nose height, and more positive camber as a result.
Also, pulled over here for reference are some other useful posts I've read:
Originally Posted by Brutal
the bigger issue is bad upper shock mount that deteriorate and drop the ride height and drops camber more negative.
But if your camber is less that -1.5 and not closer to -2, I dont care what anyone says, it will NOT prematurely wear the insides, but not setting toe correctly damn sure will and fast. If you dont check suspension deflection when setting toe like Mercedes has wanted for decades youll screw yourself. You drive on roads that take all the tolerances out of the suspension as you drive, ball joints, bushings, wheel bearing etc. You dont drive on an alignment machine! I preach this on forums till Im blue in the face. You can set front toe all day and Ive over the years, pressed on front tires and watch a "in the green" toed in front and go toed out into the red which will quickly wear out the insides of the front tires. When you simulate by pressing out on the insides of the front tires to simulate what the road will do to the suspension as you drive.
AND PS just cause its green doesnt meen it wont wear either. I always always toe in past the middle and my customers cars (if they dont hit crap) dont wearout unevenly. Also you may or may not be aware that on a XK most of tires youll put on are NOT gonna give you 30-40k, most will be 20-25k. as long as theyre wearing evenly. The cars are ment to stick in corners not drive on a set of tires for 40k. Look at the treadwear ratings when buying tires if your more concerned about longevity
Originally Posted by OregonJag
Let me add to Brutal's comments that 13 year old springs will also cause the front to sag and the camber to go out. I replaced my spring pads and thought it made a big difference. Then I replaced my 15 year old springs and it made a lot more difference.
Check your ride height per this chart and see where your car is. To measure it, park it on a flat even surface like the concrete of a weight station or large parking lot. Before I changed my pads and springs I was down over an inch on the driver side. Pads made about 3/8 -1/2" difference. The springs made the rest and they were not evenly sagged on left and right.
And I would have set the front toe to .16 instead of .12 Ive just experianced still innner tire wear at .12, but you really need to push out when aligning to see where the tire/toe settings move to and adjust static setting accordingly
I just push out with my arms evenly at the same time to do this. Its gives you an idea of where EACH cars toe will go when driving. As an example if Ide have set a front toe setting static to .16 they will useally move to .6-.12. SOOOO if youre at .10-.12 static, youre likely gonna be toe'd out when driving. And then there are the cars that have to be "toe'd into the read" cause when checking deflection they move out ALOT
Old Jul 11, 2013 | 04:20 AM
andyps's Avatar
Do you know what the ride height should be based on the post from OreganJag?
Pretty sure mine is wrong as it sits lower at the front than the rear.
Old Jul 11, 2013 | 04:31 PM
99ragtop's Avatar
Default Thanks Waterboy!
Wow! You sure dug-out the info for me! My XK8 is lowered,but for 10 years! I've had shocks/struts replaced...but mounts are crumbling! The importance of Toe was overlooked by me though. Thank you again, Andy
Old Jul 12, 2013 | 02:12 AM
H20boy's Avatar
Andyps, go up into this subforum's FAQ thread and click the Vehicle Specifications document link. That has them. Sorry, mobile right now.
Old Jul 13, 2013 | 07:08 AM
99ragtop's Avatar
Default Rear shock/strut upper mounts
Does it make sense to replace rear upper s/s mounts prior to shimming the differential? My rear camber is negative 3+ as well.
Old Jul 13, 2013 | 09:02 AM
Paul Pavlik's Avatar
Yes.
Based on my experience, changing from the standard 4.0mm Shims to the Max Available 7.5mm shims will not , by itself, give you enough change to get you to the Factory Specified Camber Range.
Old Aug 18, 2013 | 10:40 PM
99ragtop's Avatar
Default D-DAY for my lowered XK8
After much deliberation, and chewing up brand new tires, the negative cambers in the mid-3's are going away tomorrow. I procurred junk-yard original springs/struts, mounts, and a pair of rear rotors. While my cat will raise 4-5 inches, the upside is that I'll be back up to cleavage viewing level. Thank you to all who tried to help solve my negative camber problem. Cheers, Andy
