XK8 Pass seat problem
Old Apr 18, 2017 | 09:40 AM
Ship's Avatar
Default XK8 Pass seat problem
Had some one move the seat all the way forward using electrics now no movement in any of the electrics. Is there a fuse that might have gone out if so where. Any ideas would be a great help. Lance Car is 1999 XK8
Old Apr 18, 2017 | 10:01 AM
larueb's Avatar
As I recall the fuse is in the inside the car. Either the fuse box on drivers or passanger side. Sorry I can't give you the number as my car is not here now. the cover will tell you which one. FYI on mine I placed a larger fuse in and it works fine. Mine would blow when my wife would try and move seat forward before raising the height.
Old Apr 19, 2017 | 12:10 PM
grantorino62's Avatar
Yes, check the fuses and NEVER install a higher amp. fuse! to fix an issue.
Old Apr 19, 2017 | 01:12 PM
wymjym's Avatar
When I purchased my 2005 xk8 I moved the passenger seat back the entire distance and it would not move forward.
I swapped the drivers control module with the passengers and moved the seat into the best position. Then opened up the removed unit only to see that the traces were worn through. I repaired them, put that module back in place and all was well.
wj
Old Apr 19, 2017 | 05:01 PM
avern1's Avatar
Somethiing you might want to try is reaching up under the to the back of the seat control module and press on the connector. Since you said it occurred when you moved the seat fully forward you might have unseated the connector.
It would also be most helpful if you put the model year in your post or if you add it to your signature it will always be there.
Old Apr 20, 2017 | 10:41 AM
Ship's Avatar
Default Seat problem
Year of Jag XK8 1999.
Thanks to all
Old Apr 22, 2017 | 09:51 AM
Ship's Avatar
Does anyone have a copy of the diagram of the parts under the seat or a lead to where to find. Have not fixed problem yet. Would be helpful if I new what I was feeling. Ship
Old Apr 22, 2017 | 05:25 PM
Cabel's Avatar
Ship, did you check the seat switch? My son ran the passenger seat all the way forward (pinning himself under the dash, he's a big boy - pretty funny, actually) and it was the switch. I took it apart and found one of the little guide pins had dropped out, so the switch handle wasn't actually making contact with the circuit board. 15 minute fix.
-Cabel
Old Apr 23, 2017 | 11:04 AM
Ship's Avatar
Default Seat Repaired
Don't know what I did but after playing with finally got it to work.
Thanks for all your help.
Ship
Old Apr 28, 2017 | 12:36 AM
Christian Fekete's Avatar
passenger seat stuck in full backward position, the switch is not activating the motor, what should I do and how can I access the bolts in the back?
2003 Jaguar XKR
Last edited by Christian Fekete; Apr 28, 2017 at 12:38 AM. Reason: car model missing
Old Apr 28, 2017 | 04:49 PM
Cabel's Avatar
Christian,
On the seat switch, on the edge towards the rear there is a lug which is held in place using a small metal clip.Using a small screwdriver, work it in between the seat leather and the switch and push GENTLY towards rear of car, then lever the rear of the switch out, being careful of the wiring. You can then disconnect the switch pack to access the torx screws on the rear of the unit and take it apart to see if any bits are out of place. I found that my "electronics" in the switch where fine but the plastic "finger handle" wasn't making good contact with the circuit board.
