XKR 5 speed same as XJR 5 speed??
Old Oct 26, 2014 | 09:40 PM
XxSlowpokexX's Avatar
Default XKR 5 speed same as XJR 5 speed??
Seems like a silly question but I couldn't find the answer. Looking for a core to tear apart. Sometimes things such as tailshafts are different
Thanks!
Damon
Old Oct 27, 2014 | 10:22 PM
someone has to know this:O)
Old Oct 28, 2014 | 01:08 AM
avos's Avatar
They share a lot of parts, and if you mean just the gear box, then yes these are the same. The drive shaft is different again, as is the diff (pinion).
You can also check the JEPC (Jaguar Electronic Parts Catalogue), it’s still somewhere linked here.
Old Oct 29, 2014 | 07:37 PM
Thanks. Yes just the gearbox. Mine used and abused and I can get a low mile unit out of an xjr. With some makes of cars the transmission is identical but things such as the tailshaft may be longer or linkage on the opposite side. Kind of ruled out one and was curious if the unit itself was bolt up and go.
PMKimpton
Aug 3, 2019 08:22 PM
FeralJag
Jan 11, 2016 05:07 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
edtexas
Sep 5, 2015 10:49 AM
AL NZ
Sep 4, 2015 08:39 PM
