XKR Airfilter
Old Mar 28, 2015 | 12:03 PM
SeismicGuy's Avatar
Originally Posted by Gus
You or your car will NOT go to hell for using a K&N oil type filter!
I agree. This particular subject brings out the most passionate arguing on both sides of the issue. I used one of these on my last car for 14 years and have has one on the Jaguar for 6+ years and never had any problems. Granted I was realistic in not expecting any appreciable performance difference one way or the other and I went to reasonable lengths to keep the filter clean and not over-oil it.
Doug
Old Mar 29, 2015 | 08:54 AM
RaceDiagnostics's Avatar
Guys, I have around 2000 customers using my diagnostic equipment and there is a significant correlation between those reporting low MAF readings and those using oiled filters. I am talking in the range of 5 to 20% lower than expected.
A couple of points to note are that the ECU on older cars will probably not throw a code till the MAF is reading more than 50% lower then expected. It would seem that the MAF signal into the control of the engine is a weak one so you may have no clue that it is reading low.
Is there a consequence to the MAF reading low? It is clear that a butt dyno will not tell you it is low and maybe the engine will still be putting out the same power despite the incorrect MAF reading?
So I feel there is a relation but that the consequences are minimal, even so I decided to stick with paper.
Those who are running with oiled filters with a stock set up, it would be good to know what your peak MAF values are at WOT, max RPM.
That way we could see if there was a relation on our JAGs, all my experience so far has been on VW Audi group cars.
Old Apr 1, 2015 | 07:09 AM
Majik Lasers's Avatar
Default Mina Performance Intake Kit
Do the same negative affects apply for the Mina kit, as it also has a cone filter? According the their site the "Kit has been dyno tested to produce over 12HP (at the rear wheels)."
Old Apr 1, 2015 | 11:59 AM
SeismicGuy's Avatar
I would think that any benefits due to increased airflow would be cancelled out by sucking in hot air from the engine compartment versus outside air.
Doug
ricwel
Jun 23, 2023 05:14 PM
ziondio
Sep 29, 2015 01:58 PM
ziondio
Sep 28, 2015 11:24 AM
vacolorito
Sep 25, 2015 09:29 AM
