I’m removing the rear A-frame on 2006 XKR. The two captive bolts on upper side, adjacent to main bushes are fine thread and 19mm A/F. My hex socket (new with relief ground off) is a sloppy fit. I have very little room to manage wrecking bar in the wheel arch so need a tight fit. What is the best way to tighten the fit or get improved access to the bolt head? Can I avoid dropping the rear axle?
ps the fit on my other Jag 19mm A/F bolt heads is snug?
