XKR vs. XK8 Brakes
Old Apr 25, 2022 | 06:39 PM
tmattson57's Avatar
Default XKR vs. XK8 Brakes
Is the XKR non-brembo brake setup the same as the XK8's?
Old Apr 25, 2022 | 10:31 PM
zray's Avatar
I think they both use the ATE calipers and same size rotors. (325 or 330 front & 305 rear I think)
those stock base brakes on the XKR are very good , and with the right pads can perform superbly for spirited street driving.. having better than OEM pads makes all the difference in how the stock brakes perform, I use the ebc red stuff pads and have yet to experience any fade or reduced effectiveness, even in the mountains.
Z
Old Apr 26, 2022 | 05:37 AM
Pistnbroke's Avatar
305 or 325 front with one pot calliper or 325 with Brembo.You can change the 305 for 325 with the same calliper but you need a different mounting bracket about £60 or $80. This evidently only gives a 6% improvement . I am currently replacing my discs (305)and pads with new as I got some 305 NOS very cheap .so will let you know.
Old Apr 26, 2022 | 08:15 AM
zray's Avatar
it also depends on the model year. The earliest cars had the 305’s front and rear, Including the XKR’s. The 325’s were later (late 1999+) put on the front of both models that had the ATE calipers (the non-Brembo’s).
Z
this thread has an embedded video which goes into greater detail
https://www.jaguarforums.com/forum/xk8-xkr-x100-17/jaguar-xk8-xkr-x100-brakes-239557/
O&DR
Nov 7, 2020 02:36 AM
peterg19
Jan 30, 2015 01:02 AM
