XKR wheels on 2001 XK8
Old Oct 19, 2013 | 08:13 PM
noterman's Avatar
Default XKR wheels on 2001 XK8
Is it ok to put 19 inch XKR wheels on my 2001 XK8? The wheels are 8.5 inch wide in front and 9.5 inch wide in the rear. 245/40/19 front tires and 275/35/19 rear tires. I am thinking at the least it would mess up my speedometer and maybe the TCM. Has anyone done this and had good luck? Thanks
The donor wheels are from a 2007 XKR.
Old Oct 19, 2013 | 08:24 PM
Jag#4's Avatar
If you have the factory 18" wheels, you already have the staggered widths. because those tires have the smaller sidewall aspect, you should be OK. Go to TireRack.com or Discount Tire's website and you can read articles about "plus sizing".
You should also be aware of offset. Someone on here with the 19" OEM wheels may know. Which wheels are you buying?
Old Oct 19, 2013 | 09:34 PM
ccfulton's Avatar
What year XKR are they from?
I do to believe any stock wheel for an X100 had a 9.5in width. They were either 8 and 9in for the 18 and 19 diameters or 9 and 10in for the 20 diameter.
Old Oct 20, 2013 | 07:04 AM
noterman's Avatar
Sorry I did not mention it the wheels are from a 2007 XKR
Old Oct 20, 2013 | 08:54 AM
ccfulton's Avatar
They will only fit by way of an adapter, the bolt pattern is different on the 2007+ X150.
Old Oct 20, 2013 | 02:34 PM
Sentinelist's Avatar
Yep. I just found this out recently as well. Stick with 2006 or earlier X100 wheels.
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
PMKimpton
Aug 3, 2019 08:22 PM
Skeeter
Sep 17, 2015 08:15 PM
edtexas
Sep 5, 2015 10:49 AM
