Diesel variants - All models Visit here for discussions on diesel powerplants and the impressive torque / mpg figures achievable....
The Definitive Coolant Bleed Procedure
Old 10-22-2014, 08:02 AM
That Geezer's Avatar
Default The Definitive Coolant Bleed Procedure
Hi Folks,
I hope you're all well.
I am looking for a line by line guide to bleeding the coolant system, there are bits here and bits there, people being smart and others not so.
Basically I had a water leak from the water pump to the engine, i replaced the lost coolant, about 3 liters. I used the bleed screen on the water pump to expel air from that side of the system but my temp gauge on the dashboard is now showing 1/4. Strangely if i turn off the car and turn it back on again the temp shows the true temp in the mid position but then the gauge drops back to a 1/4 within seconds.
Please give a line by line guide EG:
  1. remove filler cap
  2. turn on car
  3. turn on heater to full
  4. ........
Thanks Peeps
Old 10-22-2014, 08:18 AM
Bleed screw sorry
Old 10-22-2014, 09:06 AM
Received 2,255 Likes on 1,840 Posts
You may want to post your question in the tech section for the particular car model you've got. The procedure for an X-type is very different than for an S-type for instance.
That Geezer (10-22-2014)
Old 10-22-2014, 09:31 AM
Old 10-23-2014, 01:54 AM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
That reports an error.
Mac Allan
07-20-2020 05:46 PM
RaceDiagnostics
04-04-2016 04:00 PM
vwbusbits
10-13-2015 03:43 AM
Johncy2000
10-02-2015 01:05 AM
Quick Reply: The Definitive Coolant Bleed Procedure
