Diesel variants - All models Visit here for discussions on diesel powerplants and the impressive torque / mpg figures achievable....
The Definitive Coolant Bleed Procedure
Old Oct 22, 2014 | 08:02 AM
That Geezer's Avatar
Default The Definitive Coolant Bleed Procedure
Hi Folks,
I hope you're all well.
I am looking for a line by line guide to bleeding the coolant system, there are bits here and bits there, people being smart and others not so.
Basically I had a water leak from the water pump to the engine, i replaced the lost coolant, about 3 liters. I used the bleed screen on the water pump to expel air from that side of the system but my temp gauge on the dashboard is now showing 1/4. Strangely if i turn off the car and turn it back on again the temp shows the true temp in the mid position but then the gauge drops back to a 1/4 within seconds.
Please give a line by line guide EG:
  1. remove filler cap
  2. turn on car
  3. turn on heater to full
  4. ........
Thanks Peeps
Old Oct 22, 2014 | 08:18 AM
Bleed screw sorry
Old Oct 22, 2014 | 09:06 AM
Mikey's Avatar
You may want to post your question in the tech section for the particular car model you've got. The procedure for an X-type is very different than for an S-type for instance.
Old Oct 22, 2014 | 09:31 AM
Hi, I have re-posted to Jaguar Forums - Jaguar Enthusiasts Forum - Search Results is that ok?
Old Oct 23, 2014 | 01:54 AM
JagV8's Avatar
That reports an error.
Mac Allan
Jul 20, 2020 05:46 PM
RaceDiagnostics
Apr 4, 2016 04:00 PM
vwbusbits
Oct 13, 2015 03:43 AM
Johncy2000
Oct 2, 2015 01:05 AM
