Mongoose JLR 64 bit drivers needed
Old 12-11-2015, 09:25 PM
plums's Avatar
Received 2,166 Likes on 1,610 Posts
Default Mongoose JLR 64 bit drivers needed
Does anyone know if 64 bit drivers were ever published for
the original mongoose and not the later pro?
If someone has them, please get in contact.
Old 12-12-2015, 01:25 AM
plums's Avatar
Default and it's been done
the driver can be installed, but it has to be unpacked first:
(Solution) Mini VCI + Toyota TIS Techstream 8.x on Windows 7/8 64-bit. - Toyota 4Runner Forum - Largest 4Runner Forum
Old 12-13-2015, 01:57 AM
u102768's Avatar
Received 1,484 Likes on 907 Posts
Are you talking about "MVCI Driver for TOYOTA.msi"? If so my non-pro Mangoose won't recognise the unpacked drivers.
Old 05-22-2017, 12:46 AM
phydor's Avatar
You must do this
If you use 64-bit Windows you MUST run CMD.exe with administrative rights and execute next command:
Code:
mklink /D "C:\Program Files\JLR" "C:\Program Files (x86)\JLR"
Install drivers for diagnostic device.
Old 02-20-2022, 03:44 AM
Ced027's Avatar
Originally Posted by phydor
You must do this
Code:
i have problemp installion
can you help me
Old 04-22-2022, 01:12 PM
Salliemohamed's Avatar
If still need help let me know
Old 04-24-2022, 09:09 AM
clubairth1's Avatar
Received 2,239 Likes on 1,767 Posts
Plums I only have the Pro drivers (both 32 and 64 bit versions) and I thought they were the latest and greatest drivers? It's what I currently use and it does work.
Are you trying to run something else?
szhilian39
11-20-2021 08:43 AM
jagxjr
10-07-2019 04:50 PM
Vee
General Tech Help
03-22-2017 02:19 PM
Martyn Musch
01-29-2017 05:31 AM
mrlovt
General Tech Help
10-24-2015 12:37 PM
Quick Reply: Mongoose JLR 64 bit drivers needed
