Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Wood clear coat?
Old 05-31-2015, 01:14 AM
jerel's Avatar
Default Wood clear coat?
Jerel here looking to refinish all the wood in my 86 xj6, if poop of all of The clearcoat and am ready to Pour a new one on. I was wondering if anybody had experience with the refinishing or re clear coating jag wood. which clearcoat is the most heat resistant and won't yellow and crack as much with age?and what methods I could use to make the woodgrain pop?
Old 06-01-2015, 12:10 AM
j.w.s's Avatar
1 of 19 (07-04-2018)
Old 06-01-2015, 02:18 AM
GGG is offline
Received 16,800 Likes on 12,169 Posts
Originally Posted by jerel
Jerel here looking to refinish all the wood in my 86 xj6 .............
Jerel,
I've moved your question from General Tech Help to Interior forum. The topic has been discussed here previously.
https://www.jaguarforums.com/forum/i...wirling-51394/
https://www.jaguarforums.com/forum/i...001-xjr-44331/
Old 06-01-2015, 02:19 AM
GGG is offline
Originally Posted by j.w.s
Perhaps: ........
Welcome to the j.w.s.,
Old 06-27-2015, 07:33 PM
GGabriel's Avatar
Somewhere in your area will be a local shop that sells veneer rolls of wood. They will have different types of resin. The best is a product very similar to what Jag uses. It's expensive for a small amount but it's worth it. I've even seen it at Hobby Stores. Can't think of the name but it might be something like Liquid Glass
Old 06-30-2015, 10:47 PM
primaz's Avatar
Jaguar wood work to me is best done by a professional shop like Madera Concepts as most DIY jobs never are that good. I was lucky to have a friend whom used to do this professionally. He carefully removed the coatings and repaired and colored the wood. I used the clear materials he recommended and had a body shop do the coatings which they wet sanded in-between coatings to give it that great shine. The product was:
Matrix Systems clearcoat: $65 (one quart plus hardener and reducer)
Attached Thumbnails Wood clear coat?-dsc04766.jpg   Wood clear coat?-dsc04767.jpg   Wood clear coat?-dsc04764.jpg
Old 02-12-2016, 09:21 AM
Best stuff to use, Italian Polyester by ICA America
Larry-Cleveland
02-09-2019 03:17 PM
NS2000XKR
01-01-2017 10:41 AM
emilime75
XJ XJ12 ( X305 )
10-19-2015 09:55 PM
inactualis
10-02-2015 11:13 AM
Lawrence
XJ40 ( XJ81 )
10-01-2015 08:36 AM
Quick Reply: Wood clear coat?
