coolant, head gasket
Old 01-01-2013, 10:47 AM
darren-talbot's Avatar
Default coolant, head gasket
engine was getting hot last night. called out green flag who topped up coolant and sai he couldnt see any leaks from any hoses or water pump, and there was no water in the oil. He thinks it could be a sticky thermostat.
Is it common for v8 headgaskets to go as im a little concerned, i have noticed white steam/smoke out the exhausts when running temp is up together, but i could be being paranoid?
Old 01-01-2013, 10:59 AM
bfsgross's Avatar
darren, the thermostat can stick and should be replaced. If it was cold last night then you'd def. see the normal steam from the exhaust. If the headgasket had blown you'd def. notice due to a large cloud forming that doesn't dissipate. With engine cold, unscrew the top off of the coolant expansion tank and put your nose close to the opening, smelling for an odor of exhaust. Start and warm her up. Drive locally, observing for excessive water vapor from exhaust and coolant drop in expansion tank. Check back with us.
darren-talbot (01-01-2013)
Old 01-01-2013, 11:07 AM
thanks bfgross,
ok il get it in the garage tomorrow and get it looked at, regards the head gasket, ive notice no loss of power or performance, and when the brake down guy came out last night he checked for water in the oil, and with the engine running we took off the expansion bottle screw lid and the coolant didnt have shed loads of pressure and wasnt boiling.
Old 01-01-2013, 11:21 AM
bfsgross's Avatar
Agree. If she was mixing water and combustion there would likely be a misfire- studdering experience with loss of power. So all should be ok. Swap in a new thermostat, pronto. It's a fairly easy swap.
silkcat
04-15-2023 04:58 PM
aholbro1
08-05-2021 05:02 AM
vicom
09-17-2015 03:32 AM
bavareze
09-11-2015 01:49 AM
1964Daimler
09-09-2015 11:20 AM
Quick Reply: coolant, head gasket
