Newbie alert, S-type 4.0 has timing belt or chain?
Old May 21, 2008 | 11:27 AM
jaguars4r's Avatar
Default Newbie alert, S-type 4.0 has timing belt or chain?
Lookin to buy an 01 S-Type 4.0, the seller says the timing chain broke but isnt 100% sure, its what his local mechanic told him. I cant really trust some of these guys since many arent educated on Jags.How can I check? The mechanic said it was loose and he drove it with the timing chain loose and the now it finally broke, Also, will a 4.0 XJR motor work?
Old May 21, 2008 | 01:26 PM
cosworth's Avatar
Default RE: Newbie alert, S-type 4.0 has timing belt or chain?
4 chains. Two primary and two secondary. They don't need replacing for the life of the engine thankfully - unless you have a tensioner failure and they stretch. Happened to me and I replaced ONE chain confidently.
Sachs makes them.
Old May 21, 2008 | 08:38 PM
ibjags's Avatar
xjr motor wont fit in the stype totally different mounting
not to mention time effort and money it would take ecm/harness etc etc
as far as broken chain goes you better make sure valves arent bent or even worse broken
ive seen itquite a few timeswith totall destruction of cylinder wall and piston damaged
Old May 21, 2008 | 11:14 PM
rianbechtold's Avatar
The 4.0l is an interference engine, ask me how I know[:@]Chances are the valves said hello to the pistons when the chain broke.
As far as it becoming loose before breaking, I'd be affraid tobuy a car owned by someone so neglegent!
Old May 23, 2008 | 11:52 AM
mkaresh's Avatar
Yep, not good judgment to drive a car with a loose timing chain.
Old May 27, 2008 | 05:03 PM
mberman's Avatar
Don't even consider any model year prior to 03. The 03 have major upgrades to the electronics and the engine. It also comes standard with the nav.
Old May 27, 2008 | 06:19 PM
ibjags's Avatar
03 and later is defently the way too go if you can
as far as standard nav not true
its a option
RoyLittle0
May 25, 2023 02:38 AM
Sprayall
May 30, 2021 08:13 AM
Bowman
Sep 15, 2015 06:54 AM
Sprayall
Sep 3, 2015 07:49 PM
Bowman
Sep 3, 2015 03:17 PM
