Brake Booster Vacuum Hose Replacement
My Brake Booster Vacuum Hose on my 2004 X-Type got broken and I need to replace it and I am not sure how to remove it from Manifold and Brake Booster... I don't want to just pull because I assume there is a trick that is easy...
Could I get a brief instructions or a guide to do this ....
Thank you very much
Spyderman
Thank you very much
Spyderman
Check the reply in my post about half way down its explained how to remove the hose..
https://www.jaguarforums.com/forum/x...ication-37354/
This may or may not be related, but I just had a new clucth put in my 2002 X type and the guy broke the Brake booster hose. I have taped it up in the meantime trying to figure out why the car is over heating all of a sudden?? The two cant be related could they? After I strt the car and let it idle for about 15 minutes it starts to overheat. Then I get in the car and I see that I can shift into gears WITHOUT the clucth pushed down. This is so odd. It may be two seperate issues, as I think the themostate may be stuck after sitting for months, but it's odd how this happens after it starts to overheat. I dont think its the head gasket after a few tests as far as the overheating issue is concenered. Any help would be appreciated. Also I notcied two cables that were not connected in the engine, and I will post them here. One is almost under the battery and the other is a split type cable with heated shileding that sits towards the back of the engine. Thanks in andvance.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
