Brake Booster Vacuum Hose Replacement
Old Jul 19, 2011 | 07:48 PM
spyderman's Avatar
Default Brake Booster Vacuum Hose Replacement
My Brake Booster Vacuum Hose on my 2004 X-Type got broken and I need to replace it and I am not sure how to remove it from Manifold and Brake Booster... I don't want to just pull because I assume there is a trick that is easy...
Could I get a brief instructions or a guide to do this ....
Thank you very much
Spyderman
Old Jul 19, 2011 | 09:12 PM
DZtt's Avatar
Check the reply in my post about half way down its explained how to remove the hose..
https://www.jaguarforums.com/forum/x...ication-37354/
Old Nov 26, 2014 | 06:07 PM
curtizb's Avatar
This may or may not be related, but I just had a new clucth put in my 2002 X type and the guy broke the Brake booster hose. I have taped it up in the meantime trying to figure out why the car is over heating all of a sudden?? The two cant be related could they? After I strt the car and let it idle for about 15 minutes it starts to overheat. Then I get in the car and I see that I can shift into gears WITHOUT the clucth pushed down. This is so odd. It may be two seperate issues, as I think the themostate may be stuck after sitting for months, but it's odd how this happens after it starts to overheat. I dont think its the head gasket after a few tests as far as the overheating issue is concenered. Any help would be appreciated. Also I notcied two cables that were not connected in the engine, and I will post them here. One is almost under the battery and the other is a split type cable with heated shileding that sits towards the back of the engine. Thanks in andvance.
toronadomike
Jan 22, 2026 10:13 PM
JarodL
Mar 7, 2024 01:39 AM
Sprayall
Sep 3, 2015 07:49 PM
laserguy
Sep 3, 2015 02:02 PM
XJsc-guy
Sep 2, 2015 11:43 AM
