Misfire Bank 2 only! with P1314, P1316, P1582
Old 10-26-2014, 05:42 AM
governor's Avatar
Default Misfire Bank 2 only! with P1314, P1316, P1582
Just like to say hellow to all the members on this site, your previous threads have given me some excellent knowledge about my Jaguar.
I have just recently purchased a 2005 x type ,2.5 limited edition with dual exhaust. I have seen some members with similar issues to the ones I am experiencing, and am really hoping you guys could kindly lend me some advice.
The codes I am getting are p0302 p0304 p0306 p1314 p1316 p1582. I have a good general understanding of what mean, and understand that they all relate to bank 2.
So far I have replaced plugs/coils, 02 sensors for bank 2 upper and lower, new intake gaskets including IMT, leak tests and multiple OB2 reset's. Car has just had a brand new MOT on purchase.
The Jaguar runs fine and idles fine also, engine sounds very slightly rough. The main issue is that it keeps going into Limp Mode, mainly when idling at the lights or parked, also frequently when driving below 3000 rpm. It picks up fine with maybe a slightly slow responce. Permanent engine managment light with frequent flashing when in Limp Mode.
I have seen a few members and sites were some owners have experienced these symptoms. I am lead to belive it could possibly be a blocked Cat ( makes me think why MOT did not pick that up), vvt and solanoid issue, cam sensor.........please could you guys give me any advice on this. Many thanks advance!
Old 10-26-2014, 07:42 AM
GGG is online now
Received 16,800 Likes on 12,169 Posts
Welcome to the forum governor,
I've copied your question from New Member Area - Intro a MUST to X-Type forum. Members here with the same model will be able to help.
Old 10-26-2014, 08:48 AM
governor's Avatar
Big hello, to all the X-TYPE members here. I have gained a lot useful information from this site, so thank you for that! and finally joined up myself. As you can see from the post above, i have had some issues and would love some advice. Thanks in advance and I hope I can return the favor later down the line.
Old 10-29-2014, 06:42 PM
Jaguarfan2's Avatar
Default question bank 2 misfire
If coils bad do they still misfire? Here are
PO304
P1314
P1316
PO037
PO191
PO1229
P1647
P1603
P1000
Old 10-30-2014, 11:43 AM
governor's Avatar
Sorry Jaguarfan2, little confused about what you are asking?
aode06
07-28-2023 02:26 PM
pnwrs2000
11-17-2015 04:04 AM
carl purchase
10-14-2015 06:14 PM
reb1999
09-26-2015 08:41 AM
Quick Reply: Misfire Bank 2 only! with P1314, P1316, P1582
