water pump leak
Old 09-15-2008, 02:20 AM
mrcjr24's Avatar
Default water pump leak
I've had a water pump leak for about 5,000 miles now on my 2003 Jaguar X-Type. I make sure the coolant tank is full at all times so my engine doesn't overheat. What are the long term effects of this leak and how much longer do I have to replace it before the problem gets worse?
Old 09-16-2008, 12:24 AM
mrcjr24's Avatar
Default RE: water pump leak
Thanks. I was kinda holding out because the dealership was charging me an arm and a leg to do this. Luckily, come to find outI have a friend whose real handy with this type of stuff so I'm buying the water pump tomorrow and that should take care of the leak for a fraction of the cost.
Old 09-16-2008, 12:39 AM
ruslan35's Avatar
I have the same problem. Just wondering, how much for the water pump and where and ow much labor?
Old 09-16-2008, 10:02 AM
mrcjr24's Avatar
I got my water pump w/ gasket for $75 at O'reilly's Auto Parts. Firestone was gonna charge me $150 for the pump and $400 to remove and replace it. If you can find someone to do it for you, you'll save a lot.
Stuart Beattie (01-23-2013)
Jandreu
06-30-2022 03:10 PM
Wahooesprit
12-23-2019 02:01 PM
dsnyder586
04-04-2019 02:38 PM
Saturbo
09-08-2015 07:35 PM
Quick Reply: water pump leak
