X-Type A/C Compressor
Old Aug 27, 2007 | 05:23 PM
ken@britishparts.com's Avatar
Default RE: X-Type A/C Compressor
Can you post a pic? I can't imagine what's missing....
Old Aug 28, 2007 | 01:35 PM
tokaygecko's Avatar
Sounds like your electric A/C Compressor clutch fell off. I wonder how much Jag wants for a new one....
Old Aug 28, 2007 | 02:38 PM
Jaguar sells the clutch alone for big $$$$. Part number C2S5982. It's cheaper then compressor and clutch together, but if you have to buy it from Jag take some lubricant. I checked, we don't have a used one. Sorry.
Old Jan 7, 2008 | 06:56 PM
FactoryJaguarTech's Avatar
Indeed the missing compressor clutch debacle is more common than you may think. We always replace the compressor as it comes with the clutch and is pretty comparable in price. You may be able to get a compressor from a junk yard and just take off the clutch.
Old Jan 7, 2008 | 10:33 PM
Dennis's Avatar
ud
My question is..how in the hell do you get on it to check the nut?..I barely can see the clutch down in there with a flashlight, let a lone stick two big *** arms in there and a wrench..[&:]
Old Jan 9, 2008 | 07:15 AM
Ahh welcome to the world of the Jaguar Tech. LOL. Easiest way is from the bottom. The front lower cover is held on with 30torx screws and 3 10mm bolts. Take that off and you will get your hand in there. No nut means no clutch. Good luck.
Old Jan 9, 2008 | 08:08 AM
Dennis's Avatar
ud
Thanks..All is well, My nut is still there
Old Jan 9, 2008 | 04:47 PM
Question is can you still see out of it!!!
Old Jan 9, 2008 | 07:07 PM
Dennis's Avatar
ud
[sm=dontgetit.gif]
Old Jan 9, 2008 | 08:46 PM
Let you think about that for a while.....Nut.....Head. Eyes in your head.....ummmm maybe I should put down the pipe now...j/k
Old Mar 22, 2008 | 05:57 PM
There is one electrical connector to the compressor as this engages magnetic clutch.
You should remove compressor as you will not be able to get the snap rings off that hold the clutch in. Also, make sure you keep the shim(s) in place.
If you had a compressor failure, make sure you change the fixed orifice tube also as this will cause a restriction.
Old May 13, 2012 | 01:51 PM
sasha1772's Avatar
Guys,
Who can help me? What is exact part number with any possible cross-references for A/C compressor Jaguar X-type, 2004, 2.0L? Also, will A/C compressor from Ford Mondeo can be used as a replacement? Please advise who know the answer.
Thanks!
Paora
Feb 4, 2021 12:36 AM
millertic
Sep 30, 2015 08:11 PM
dan102877
Sep 29, 2015 06:47 PM
oldjaglover
Sep 29, 2015 03:27 PM
