cold start
Old 01-20-2012, 05:24 AM
ant17's Avatar
Default cold start
My car starts almost immediately (1/2 a crank) every morning, it's garaged.
When I go to start it after work and being outside all day it cranks several times before starting.
This happens here in the Chicago tundra when it's 20 or colder out.
Battery is new and voltage reads 12.7.
Any idea why the long crank?
tia
Old 01-20-2012, 06:30 AM
test point's Avatar
Received 1,110 Likes on 932 Posts
My idea would be along the lines of:
20 degrees x engine oil viscosity x higher internal drag x battery voltage under higher load . . . in some combination.
Old 01-22-2012, 01:35 AM
QuadManiac's Avatar
I wouldn't expect this to be too far outside of the ordinary...
At 20 deg F, most of the initial fuel spray from the injectors condenses out in the intake manifold/head before reaching the cylinder.
SD96XJ6L
01-12-2022 04:30 AM
aholbro1
08-05-2021 05:02 AM
brgjag
General Tech Help
17
09-09-2015 07:34 AM
Bones
09-08-2015 08:34 PM
tberg
09-07-2015 07:32 AM
Quick Reply: cold start
