cold start
Old Jan 20, 2012 | 05:24 AM
ant17's Avatar
Default cold start
My car starts almost immediately (1/2 a crank) every morning, it's garaged.
When I go to start it after work and being outside all day it cranks several times before starting.
This happens here in the Chicago tundra when it's 20 or colder out.
Battery is new and voltage reads 12.7.
Any idea why the long crank?
tia
Old Jan 20, 2012 | 06:30 AM
test point's Avatar
My idea would be along the lines of:
20 degrees x engine oil viscosity x higher internal drag x battery voltage under higher load . . . in some combination.
Old Jan 22, 2012 | 01:35 AM
QuadManiac's Avatar
I wouldn't expect this to be too far outside of the ordinary...
At 20 deg F, most of the initial fuel spray from the injectors condenses out in the intake manifold/head before reaching the cylinder.
aholbro1
Dec 29, 2024 06:46 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Bones
Sep 8, 2015 08:34 PM
tberg
Sep 7, 2015 07:32 AM
