Cigarette lighter fuse 1999 XJ8 L
Can anyone help me locate the fuse for the cigarette lighter on a 99 XJ8 L? I looked and can only find a cigar lighter in the book and the fuse is in not in the location in the left side rear heel kick. There is a space for the fuse but one is not there and taking another 20amp and trying to put in in the space does not work. The slot seems to big the fuse fits very loose and just falls out. This can't be the right spot because it was working a few months back.
1999 XJ8 L
2005 XJ8 L
Bill in Maryland
1999 XJ8 L
2005 XJ8 L
Bill in Maryland
1999 XJ8 L
2005 XJ8 L
Bill in Maryland
1999 XJ8 L
2005 XJ8 L
Bill in Maryland
Now this may not be correct for yours, and if not, let me know. I should be able to find an answer for you.
PS: The position you mention that feels loose is in fact not a used position. There are quite a few spots that don't have any fuses in them.
icecreamchugk (07-06-2012)
http://www.jaguarusa.com/us/en/owner...manuals/xj.htm
The 2000 Manuals are what I use, and I have yet to find a difference from my 1999 XJR. I'd highly recommend downloading these while they are still available and keep a copy on your computer.
To read them, you'll need Adobe Acrobat Reader.
http://www.adobe.com/go/EN_US-H-GET-READER
Glad it helped!
Last edited by SuperSport; 06-28-2009 at 11:34 PM. Reason: Wrong Manual. Changed to XJ
Guest
Posts: n/a
1999/2000 XJ8 Downloadable Manual
Hi,
First I'd like to thank you for posting the Cigar Fuse location pages. It will help me resolve that issue.
I went to download the 99 Manual but it is the same one I own and it does not reflect the information you posted. Is it possible for you to post the manual to this site?
http://www.mediafire.com/?sharekey=3...e4b9ac475cdcd3
Let me know if there is any problem with any of these.
EDIT: Yes, I noticed that Jaguar changed their site, and these files are a LOT harder to find now. I just keep them on my computer.
Driver's Manual Wrong?
I have a 99 XJ8 and the manual supplied with my car says that the cigar lighter is in the right hand heelboard, position 14. There is nothing there. I searched this site and found this post. After reading it, I checked out fuse #5 in the luggage compartment. Sure enough, it was blown. I replaced it and all works. My manual says the fuse I just replaced is the left and right seat timers. I downloaded the 2000 manual that was referenced. I find it odd that the manual that came with my car has the wrong fuse diagram. Thank you so much for posting this information, I never would have found it on my own.
Blue_XJ8 (02-17-2014)
FYI here's where you can download the comprehensive electrical diagrams for your Jag - virtually any year/model:
http://www.captainjaguarscathouse.co..._Reference.htm
Thanks!
Thank you so much for the link to the manual. I now have it saved to my computer.
Yes, there is a fuse box under the heelboard -- I found that, and slot 14 was not in use. I had to use the manual for the 2000 XJ8 for the correct diagrams. Why the manual for my 99 XJ8 is wrong, I don't know. All I know is that without this thread, I never would have figured it out on my own!
Cigarette lighter
I have checked all my 25 amp fuses and I still cant get the lighter socket to work. I have a funny feeling the complete cylinder may be bad, Cause there is some rust inside of it.
Does anyone know if there is an easy way to access the cylinder to take it out?
I have tried to twist it from the inside but Im worried it might snap.
Neither the front nor rear lighter sockets worked on my new Jag. I really didn't care until I went to plug in my radar detector tonight. I found a blown 25 amp fuse in position 5 in the fuse box in the trunk, next to the battery. Replaced it and both lighters work now, thanks!
(BTW, it was kind of creepy that I read this post right before my Wife and I went out for an evening drive in the XJR. I did not know that the lighter sockets did not work. She was amazed when I opened the trunk, found the only 25 amp fuse in the box, replaced it and the radar detector works now! You guys make me look good! )
Hi
Make sure you remove the battery ground cable (negetive post). You need to remove the center console, then pull out the cigarette lighter from it's cigarette lighter housing (if it is not already removed).
Now you can remove the cigarette lighter housing (the cylinder is you are referring is the housing).
To remove cigar lighter housing:
Remove tape securing harness to console underside.
Slacken and remove retaining ring from underside (of cigar lighter housing) and remove housing complete with cable.
Jim Lombardi
Jim Lombardi
