Ouch, dead motor?
Old 01-15-2014, 12:47 PM
poisonpill's Avatar
Default Ouch, dead motor?
Hi guys, I'm hoping someone got some good news...
I drove my 98 xjr 80-90mph the other day and it was fine. Yesterday I started it up and started hearing what sounds like misfires and the engine was running rough. White smoke was coming out the tailpipe and the low coolant light came on.
Sounds like blown head gasket? Can I even creep it to a shop or does it require a tow?
Thanks for your help.
Old 01-15-2014, 02:54 PM
JagV8's Avatar
Received 4,484 Likes on 3,902 Posts
It doesn't have to be the HG but in case it is I'd avoid driving it. Hang on to see what others say...
Old 01-15-2014, 03:44 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Sure sounds like a blown head gasket. If you drive it reasonably, I don't see what damage will occur on a SHORT trip to the shop. And... get the shop to save the blown gasket so we can compare pictures.
Old 01-15-2014, 05:00 PM
poisonpill's Avatar
How much did it cost to fix?
Old 01-15-2014, 06:50 PM
avt007's Avatar
There is a risk of hydraulic lock, where the cylinder fills with water, and the starter can't turn it over. I'd tow it.
Old 01-15-2014, 06:59 PM
sparkenzap's Avatar
Well, you are right about hydrolock during the startt, but its highly unlikely after a start. On the other hand, I agree that just trying to start it at all could bend the rod.
I fixed mine myself- the cost was measured in arthritic pain, scraped knuckles, and a few hundred bucks worth of parts! ..And a pissed off wife who lost her parking space for way too long!
Old 01-16-2014, 08:07 AM
jaguarbill's Avatar
You could check the compression on all cylinders also.
Hint, remove all of the plugs before testing for 2 reasons:
1 - it cranks faster.
2 - it allows you to see gasket failure between cylinders.
carl purchase
10-14-2015 06:14 PM
3jagfamily
10-01-2015 01:49 AM
oldjaglover
09-29-2015 03:27 PM
bjg625
09-28-2015 07:47 PM
Quick Reply: Ouch, dead motor?
