Stuck in Valet Mode
Stuck in Valet Mode
I bought a 1998 XJ8 last November (I love it). However, I must have pushed the "valet mode" switch, & now I cannot open the trunk with the center button as I used to be able to. I can only use the black key (the only key I have). If I open the trunk before unlocking the door, the alarm beeps at me, & then in a short while, goes off (unless I quickly unlock the door).
Any suggestions as to how to get out of "valet mode?" Thanks...Bob
if you have the master key open the trunk with it, and disconnect the battery (its in the trunk) for like 1 min and plug it back on. should reset the computer. if not take it to the dealer. sometimes they are free. just drive it straight into service. dont spend time talking to an advisor lol they try to find a way to charge you. look for a machanic walking around.
Valet isn't worth the bother unless you're forever going to movie premier's or dodgy golf clubs!
Useless in my book, now if it limited the car to 30mph........
stuck in valet mode and trunk lights don't work.1998xj8
I could not open trunk from the button inside or outside vehicel, was stuck in valet mode. I noticed that lights were not working in the trunk also. Open trunk and pull down the back cover, also a black curved cover on the trunk hinge on the right side. I found four broken wires in the small harness that comes off the big harness, thease went toward the lights and two were the same color for the lights. They r color coded and the black were ground. Purple fixed the lights and the other fixed the trunk buttons, works great now and I probably saved myself $500 at the dealer. Good luck and thank you all for the hints alone the way..
if the key-fob does not work (or you do not have one), go to an authorized jag dealer. talk directly with a mechanic (not an office manager or salesman - they will rip you off with a hefty, undeserved service fee). 1. trip the valet system with a hand-held jag computer (5 minutes duration) - have the door closed and ignition off (you will see the status alternatively change in the hand-held computer display from active to not active - this is good). 2. disconnect the computer 3. start the engine with the black key (this is necessary and permanently disables the active state in the security system). You must use the BLACK colored key. push the trunk button on the dashboard in the cabin; you will hear the 'click' in the boot. Open the trunk from outside (depress the button). MOST IMPORTANTLY: TIP OUT THE MECHANIC GENEROUSLY - HE/SHE JUST SAVED YOU 200 BUCKS!
It's one thing if you know a technician personally and he or she is doing something for you as a friend. Everyone has perks where they work and I'm always appreciative when a close friend does me a favor. But this isn't what you're suggesting. If you came to or called my dealership and asked for some help, I'd do my best to help you out. But if you approached my tech and offered to tip him -- basically stealing -- he'd tell you to talk to an advisor first. I would then make sure you never even heard the word coupon in this building. You get out of people/situations what you bring to the table. Maybe some dealership screwed you, I don't know. If you've had a bad experience somewhere, that stinks. I wish all advisors were as nice as I am. Seriously think about how disrespectful it is to approach this situation in the manner you're suggesting.
bdboyle (06-27-2015)
Jzar
09-27-2015 02:55 PM
