Modifications to Jaguar f type
Old Apr 24, 2024 | 10:03 AM
TylerKrad's Avatar
Default Modifications to Jaguar f type
Hi everyone! just want to start a thread to see some modifications that people have done. This is just to get ideas for me and so everyone else can get some. I have done the Maxton design side skirts, front lip, and got a rear diffuser extension off eBay which looks great because the Maxton one was too big in my opinion. Also want to know if anyone has done the aluminum coolant system from Euro Amp. Random but will probably need to be done at some point sadly.
Old Apr 24, 2024 | 10:12 AM
DJS's Avatar
DJS
Welcome to the forum. Here are search results for ‘modifications’, which comes up with a zillion threads for mods folks have done…
https://www.jaguarforums.com/forum/s...rchid=15307245
There are also many threads related to Euro-amp and aluminum cooling components. Search results for ‘Euroamp’…
https://www.jaguarforums.com/forum/s...rchid=15307250
Old Apr 25, 2024 | 12:35 AM
Cgo's Avatar
Cgo
Pulled the actuve exhaust fuse, lowered on KW adjustable coil overs, and 21" wheels with Pilot Sport tires. Also some hood stripes... lol
So far...
Old Apr 25, 2024 | 05:32 AM
F-Type-Type's Avatar
Fantastic license plate. Car looks fabulous.
How are the KW's compared to OEM? I am considering installing the KW coil overs (not the lowering springs) but haven't seen any F-type owners share their experience with them.
Old Apr 25, 2024 | 05:47 AM
CJSJAG's Avatar
Great license plate!!
Old Apr 25, 2024 | 07:21 AM
TylerKrad's Avatar
looks awesome, how different does it sound with the fuse pulled, ive been curious on how it sounds.
Old Apr 25, 2024 | 08:16 AM
CJSJAG's Avatar
Sounds louder!!
Drones on highway drives.
Replaced mine - too much drone on long runs.
Old Apr 25, 2024 | 08:36 AM
TylerKrad's Avatar
does it still have the active exhaust if you pull it?
Old Apr 25, 2024 | 08:39 AM
CJSJAG's Avatar
No. Effectively removing the fuse bypasses the switch which stays illuminated.
Very easy to remove the fuse and see how you like it.
Old Apr 25, 2024 | 09:54 AM
TylerKrad's Avatar
Seems easy enough. I dont have mufflers or anything on my car so the switch no longer works anyway.
Old Apr 25, 2024 | 10:21 AM
Thunder Dump's Avatar
If you have no mufflers than pulling the fuse won't change anything because you've already removed the valves altogether.
Old Apr 25, 2024 | 11:36 AM
TylerKrad's Avatar
Yes I know that, I was just curious how it affects the newer models because I have a 16'
Old Apr 25, 2024 | 12:20 PM
CJSJAG's Avatar
How do you get away with having no mufflers??
Old Apr 25, 2024 | 03:46 PM
Zen Beer's Avatar
Depending on the state mufflers aren't a requirement. For example, in TX mufflers are technically required, but not part of the inspection process. I installed something similar to these on mine so technically legal, but does jack to reduce that wonderful exhaust note!
Amazon.com: Carven Exhaust R-Series Performance Muffler 2.5 : Automotive Amazon.com: Carven Exhaust R-Series Performance Muffler 2.5 : Automotive
Old Apr 26, 2024 | 07:52 AM
Cgo's Avatar
Cgo
Thanks! Mine are set at about .8 inch lower. The ride is stiffer but thr handling is sharper. I set my dynamic mode for the suspension to stay in comfort which is like Sport mode now. Anything beyond comfort would be jarring. Turn-in is much flatter, sharper, and more responsive.
Overall, I really like the KWs.
Old Apr 26, 2024 | 07:56 AM
Cgo's Avatar
Cgo
With the fuse pulled, it snaps and pops more, like the pre face lift cars. It is louder all the time not just above 2500 rpm when the valve would normally open. I dont think it drones at highway cruising but then again, i wouldnt care. Lol One of the main reasons I decoded on the F Type R over competitors was the sound they make.
Old Apr 26, 2024 | 12:12 PM
newskatercat's Avatar
Veteran: Marine Corp
Cool ModificationsTo F- Type
Install Splash Guards to front, as is on the back!
Powdercoat OEM wheels Black, and paint side skirts Black!
Old Apr 26, 2024 | 09:29 PM
TylerKrad's Avatar
I noticed you have your coolant pipes upgraded. By this you mean the Y-pipes? and did you do all aluminum parts like the water pump and all that? just curious. And I hope it's legal in CT, muffler place said it'll pass emissions but honestly not sure. It's extremely loud.
Old Apr 26, 2024 | 09:30 PM
TylerKrad's Avatar
Looks awesome. Not much needed to be done on an SVR, they already look perfect
dcompain
May 9, 2020 04:02 PM
PapasJag
Nov 18, 2016 11:51 AM
Ubad2
Aug 25, 2016 07:37 PM
handychgo
May 2, 2016 10:32 AM
