Tank gas sending unit replacement
Old 12-10-2022, 05:22 PM
earny's Avatar
Default Tank gas sending unit replacement
Hi colleagues, the tank gauge in my early XJR from 1997 is working erratically and - after filling up the tank - varies between full and empty. I suspect a faulty sending unit. How do I remove the unit as shown in the picture?
After searching the forum I only found infos related to the later version with the unit on top of the tank. Thanks in advance, Bernd
Old 12-10-2022, 08:41 PM
xalty's Avatar
Received 1,038 Likes on 834 Posts
just beat it like a pump lock ring
earny (12-11-2022)
Old 12-10-2022, 09:08 PM
M. Stojanovic's Avatar
There is a special tool for this but you can make one. I read hat the locking ring can also be removed by tapping on it (screwdriver and hammer).
earny (12-11-2022)
Old 12-11-2022, 03:27 AM
earny's Avatar
Perfect, that helps a lot!
Ken Cantor (12-11-2022)
LnrB
10-05-2022 09:19 AM
here2for
08-09-2017 07:35 PM
Mike V
01-21-2012 04:12 AM
2003 XK8
03-05-2011 09:33 AM
jeffrimerman
09-14-2010 09:23 AM
Quick Reply: Tank gas sending unit replacement
